Gasket set for 1HDT engine wanted
My turbo packed a sad some time ago and went through the engine. I picked up a second hand engine for it which got me back on the road. Decided to strip down the old engine to see what the damage was. All I have found wrong is a few bits of turbo blade imbeded in No1 piston. There is no sign of any damage to the bores pistons or rings. Have decided to put it back together and put it back in my truck to see how it runs. The engine is currently completely stripped so I need a complete gasket and seal kit. Can someone advise me best place to get one. I thought I would replace all engine seals at the same time.
Re: Gasket set for 1HDT engine wanted
I buy all my gasket sets from ACL because work uses their industrial gaskets. I like them and are cheap thru work. Just my 2c
