Installing internal regulator alternator in 93 Hilux
Having problems. Check in here for answers, failing that post your problem.
robssei
Post by robssei »
Hi guy! Looking to install a new alternator in the mates hilux, and hoping to get some wiring tips from those who have completed the conversion from an external regulator setup to the internally regulated setup. Found this thread with a post specifying which outputs from new alternator go to correct wires on original external regulator output plug. Hoping someone might confirm. All help much appreciated!
viewtopic.php?t=37336
Petemcc
Re: Installing internal regulator alternator in 93 Hilux
Post by Petemcc »
Just updated the old post. From memory this all worked a treat.... Though I never did quite get the battery light right and it never comes on even when alt not charging.
Pete
Return to “Having problems?”
