Springs
Posted: Thu Sep 27, 2018 12:58 pm
by pudd99
Whats the advantages and disadvantages of coil spacers?
Re: Springs
Posted: Sat Sep 29, 2018 10:50 am
by BlakeNZ
advantages- very cheap lift.
Disadvantages- there is debate as to whether it changes your effective spring rate. ie somehow a 30 mm spacer can give you a 60mm lift.(True story- happened to me, carefully measured before and after) Sometimes the spacer can dislocate under extreme flex(say a wd21 terrano with no rear sway bar), but generally cable ties can prevent this. Spacers that are the exact correct size for your vehicle will generally not dislocate.
Re: Springs
Posted: Wed Oct 10, 2018 7:30 pm
by pudd99
So how much longer shockies would i need to go with?
