But if a noob question but I couldn’t easily find this out. I’m looking at a buying another land cruiser, this time a 80 series.
It’s 1997 with the 1hdft
No center diff lock.
So does that means it’s AWD?
What does the transfer box do In regards to the power front/back ratios or is it fully open?
Thanks
Land cruiser 80 series- AWD or 4WD?
- prado_boon
- prado_boon
Re: Land cruiser 80 series- AWD or 4WD?
I've been researching this for two days now and I still don't have a definitive answer.
1) Is the VC only on the t-case's rear output ?
2) Does the center diff AND the VC lock when in low (or you've installed a CDL switch) or does the VC not lock up ? If so, it's AWD but with a LSD effect on the rear axle, right?
I'm trying to simply figure out if you can still achieve a 50/50 front axle/back axle power delivery, just like the earlier "center diff lock" models ?
Is this correct or not? I understand how viscous couplings and differentials work I just can't find out if the center diff still locks and the VC locks (or is bypassed somehow) when in "low" or you've installed a CDL switch.
- skid
- Tyre Man
All I can come up with is this ........
[img] 16.0 80 Series Specific Info
16.1 Full Time 4WD
All 80 series Cruisers sold in North America and Europe are full time 4wd. In
Africa and Australia, a part-time system is still available. 80's produced
between '90-'91 have an open center differential which is lockable in 4HI and
automatically locked in 4LO. From '92 on, vehicles with ABS had a viscous
coupling that sent a maximum of 30% torque the non-slipping axle. The
differential is lockable in 4HI and automatically locked in 4LO.
[/img]
16.1 Full Time 4WD
[/img]
- prado_boon
I've just seen this:
http://www.off-road.com/trucks-4x4/tech ... 53202.html
Soooo... it must disable the VC?!?!
"The Land Cruiser runs with an open center differential in high range (4HI). When low range (4LO) is engaged, the center differential locks, giving a true 50/50 power split to front and rear axles. It also shuts off the ABS brakes"
