Shorten front pto shaft
Posted: Tue Jan 28, 2020 10:19 am
by kiwibronco
Hoping people still check this site. One more pto question. I've set my winch back z bit from std and now front shaft from engine mount bearing to winch distance is shorter. I'm about 25mm away from bring sble to slip it over the winch shaft. Anyone cut and shortened the front shaft? I was thinking cut 25mm out just behind the front joint sleeve and weld? Does that work?
Re: Shorten front pto shaft
Posted: Wed Jan 29, 2020 5:00 pm
by Twodiffs
Can't help you either way mate, once upon a time this forum used to go off every night, that's the result of social media I guess.
I don't see any reason it wouldn't work though.
Posted: Thu Jan 30, 2020 10:20 am
by kiwibronco
Thanks twodiffs. Yeah mate I use to be on here a fair bit and lots of good knowledge out there. Seems to have dried up. Re shortening the shaft. Yep had z chat to a guy that's fine it so gonna get it sorted. Cheers.
Posted: Wed Feb 05, 2020 4:39 pm
by Beer_Cruiser
Ha I would check in here at least once a day . This is first time this year....
I shortened the PTO shaft on my 40.
Just cut out the bit I don't need layed the two bits of the shaft in a peace of angle to keep them straight and welded them. Still working 15 years later...
