Window Washer Pump
For all Nissan related topics
webfish
Window Washer Pump
Post by webfish »
1990 Safari 4.2
Where in the heck is the window washer pump? Mine doesn't work and has just failed a warrant. I cannot find it in the manual so would appreciate some direction to avoid pulling things apart I don't need to :D
Smurf
Re: Window Washer Pump
Post by Smurf »
Aren't there two pumps plumbed directly into the bottom of the washer reservoir? One pump for the front and one for the rear window?
webfish
Post by webfish »
Smurf wrote:Aren't there two pumps plumbed directly into the bottom of the washer reservoir? One pump for the front and one for the rear window?
Thanks mate, you're right. It's a bit confusing because the big reservoir seems to be feeding to the rear window? Although there are two pumps on that one. Anyway, I'm on the right track now. Cheers
42south
Post by 42south »
Hi
Both mine failed over time. Genuine Nissan ones are available from Ali install on trademe, might also be available from northland, for both 24v and 12v systems. Best to go genuine for quality.
1991 SWB GQY60 TD42 safari.
DTS turbo kit.
