Rear Axle seal
For all Suzuki related topics
4x4Matt
Rear Axle seal
Post by 4x4Matt »
Just tidying up a few things on the Escudo, and have noticed that the right rear axle seal is leaking. Would anyone happen to know the best place to get a new seal?
Cheers, Matt
Clint
Post by Clint »
Have you checked the preload on the pinion bearing? Those seals usually leak 'cos the shaft is wobbly. Give it a wiggle to check. There's a crush sleeve in there that might need nipping up from time to time.
Otherwise take the seal to your local bearing shop, check suzuki genuine too, sometimes they'll surprise you & actually have decent prices.
Clint
UZJ71 Landcruiser
KTM 640
4x4Matt
Post by 4x4Matt »
*EDIT* I stated rear diff seal.. but I was meaning right rear axle seal :roll: Having my mate who's a mechanic look into it - prob go through Suzuki
Return to “Suzuki”
