i have a 94 v6 petrol terrano and its started making a vibrating
sound under the drivers side floor after its last outing at the famous aotea block! when your in drive waiting to pull out of driveway etc,
and then when im driving you feel a knockin every now and then??
i thought i may have bent the exhaust or something but theres nothing rubbing or touching the floor??
any ideas? :scratch:
whats that noise #2
whats that noise #2
Hello Ryan. I have had something similar in the past on my Terrano.
Mine was loose clampson the floor, the ones that secure the running boards to the undulations of the floor base. Solved mine by removing each one and placing a squirt of grey metal rtv type sealer under each one.
Hope this helps.
BTW your front bar looks good, well done.
Hope this helps.
Ph 0212078472
Ph 0212078472
