It looks like your centre gap there is too large, only need enough clearance to allow the dog teeth to move past each other.
Now you have run the locker for a while recheck the gap and maybe adjust the thrust washers slightly.
I've busted the pins before when I shattered a CV. Always carry spares now which I got from and engineering shop, I think they were 1/4 inch ?
Give it a rebuild and go beat it up again
Ha, i keep gettin passed around.
Tried Rocky Road, they passed me on to Powertrax.com, got an email back from them, telling me to ring them
Hey Mike, i hear you have had a locker that has blown the side part out where the pin goes, and its still worked properly after replacing the pins........
How did the damage compare to mine??
Was thinking i could repare the damage by filling the gap left by the brocken out piece with weld and grind the outside flat, and tidy up the inside of the hole with a drill. Should be sweet.
I wouldn't have thought the pins would do all that much, but they obviously do
;-p
did sean fob you off mate ? thats a bit wierd
maybe he thought you were trying to get free parts off him ?
did you ask him if there was replacement couplers available to buy and at what cost ?
From : Rocky Road Outfitters <gwbuild@rocky-road.com>
Reply-To : "Rocky Road Outfitters" <gwbuild@rocky-road.com>
Sent : Monday, 5 February 2007 12:16:47 p.m.
To : "peter Hall" <gqshorty89@hotmail.com>
Subject : Re: Busted Lock Right
Sean no longer works for us. For replacement pieces though, it is best to just go direct to Powertrax. We don't have the individual pieces and they can get them to you direct the fastest. Contact info should be at
http://www.powertrax.com
From powertrax:
Sent : Wednesday, 7 February 2007 2:00:42 a.m.
To : gqshorty89@hotmail.com
Subject : Re: Fw: Busted Lock Right.
PARTS ARE AVAILABLE.YOU CAN CONTACT OUR TEC DEPT AT 864-843-9275 X160. FOR PART NUMBERS.YOU CAN PURCHASE THROUGH RANDYS RING AND PINION AT 1-800-347-1188.
Thanks,
Michael Bolding
Customer service
So yeah, startin to feel like i'm gettin the run around, have sent them an email asking if i can sort it out via email as opposed to making a international toll call. See what the response is from that
From powertrax:
Thanks,
Michael Bolding
Customer service
- billyvanboheman
At least your not dealing with China
Last time I had to ring there for some follow up info on something I brought over there, the run around was a marathon
- billyvanboheman
I wish they had those cheap phone cards when I was ringing China
Good advise though Mike, you do generally have to ring to sort it out.
;-p
if it comes down to it mate i can pop the pins out of my spare locker and get you going asap and just leave the damaged side how it is ?
an option for ya anyway.
either that or i can wop some cap screws up to make some...or drill bits or tool steel pieces ...up to you mate
Keep that in mind Ben. Supralux is looking for some spare pins for me to.
Sayin that, i got part numbers last night from the boys at powertrax.com, and they referred me onto Randys Ring and Pinion, who i emailed this morning with the part numbers.
I'll wait and see when i get a reply tonight as to what its all gonna cost and how soon i'll get the parts.
At this stage, I'm thinkin that the kinda wheeling i do in the Safari it would be piece of mind to replace the broken coupler if its not stupidly expensive...
Otherwise i'll just replace the pins, put new shims in to reduce the clearence and run with it and see what happens. Would hate to be out somewhere in the middle of the South Island and have no 4wd.........
Its the same thing mullet
Yep, just a naturally aspirated TD42 pushing 35" Creepy's
But, i think i did most of the damage tryin to get it to unlock by drivin in 2wd with the hubs in, in a carpark late at night when i realised it wasn't unlocking. I should have pulled it straight out and had a look instead.
But i was just trouble shooting, just gettin a feel for what was and wasn't happening with it........ Honest
Chalk that one up as yet another lesson learned the hard way
falsgrave(chch) have the pin/spring kits, genuine powertrax, about $35,not worth the hassle importing unless you bring in a sizable supply. keep your tolerances near min ,they reckon and the shear pins(what powertrax call them!! are less likely to go. repaired mine less than a month ago after busting a cv/twisting axle, pins went same as yours, had done 5yrs hassle free ,but closed tolerances to min to try and reduce the chance of a repeat.
cruza wrote:falsgrave(chch) have the pin/spring kits, genuine powertrax, about $35,not worth the hassle importing unless you bring in a sizable supply. keep your tolerances near min ,they reckon and the shear pins(what powertrax call them!! are less likely to go. repaired mine less than a month ago after busting a cv/twisting axle, pins went same as yours, had done 5yrs hassle free ,but closed tolerances to min to try and reduce the chance of a repeat.
Great, thats alot more user friendly than having to import them. Cheers for the heads up Cruza.
Now i gotta find somewhere to get thrust washers from, i rang Nissan and they will be two weeks away from Japan
Gonna try the transmission places in Hamilton, see if they have another source
Its a Powertrax Lock Right Mullet. Bloody good when they are working properly, would recommend it as money well spent to anyone
Hmm, just looked at your , photos again .I think it would be wise to try and patch that hole up on the spring side, maybe someone who's good with tig may be able to help,it doesn't have to look pretty, think you may run into trouble if the spring isn't contained, if your tolerances are min the pins shouldn't have any side way's loading and you will get away with it. doesn't take much to machine up thrust washers, work on 4-5thou clearance between pinion shaft and spacer, I used a surface grinder on some donor ones out of a munched diff head, that were to thick.
Diff locks in and it works
Turns out all four pins were broken
I checked with Nissan, and the biggest available thrust washers were 1.85mm. The thrust washers in the diff measured at 1.84mm. Decided in my infinite wisdom to run with it. Short of getting some thrust washers custom made, i wasn't going to get the tolerences closer.
As for the broken coupler, i was tossing up what to do. I had a good play with it and i couldn't manage to squeeze the spring out of the gap left by the broken piece. There was plenty enough left to hold it there.
So i have thrown it together with love, and its back in and working as it should. Took it for a spin round the paddocks with the road tyres on and it behaved itself, so now it needs a test with the 35's.
I reckon it will be fine though. If not, then i know what i need to do. Get some thrust washers made and weld up the coupler.
My thoughts exactly
But for now, i've had two weekends full of important repairs that count and i'm sick of it, so i'm looking forward to gettin some R&R painting the LJ
Thanks for the imput, lets hope this is my last post in this thread for a long while
Hi DieselBoy....
I was just noseying around the old posts etc and came across this message.....something about Safari's I gather...hmmmmm
Posted: Fri Jul 21, 2006 9:26 am
Yeah, awesome guys!!!
Say gidday to Johnny for me, ask him if he's still got my standard safari springs, shocks and rear bumper that i lent him to get Gwenda's Safari certified/Vinned.
I WILL BE BACK TO GET THEM SOON!!!!!
I wonder. Perhaps get your self twin lockers and 35's and then try driving more gently??
This is pretty cheeky to say, but:
The Safari is one of the heaviest built trucks around and if your breaking stuff on it, well, you just shouldn't be!!!!!!!
Adjust driving style slightly, more skill, less speed
4x4 Motto:
As Slow As Possible and As Fast As Necessary
Pete.
Sorry..... just couldn't resist it.
Good to hear you got the lokka going again. Am considering one for the back end of the VX
4x4 Motto:
Pete.
Baldrick
91 Cruiser VX Ltd Auto Diesel Turbo *Safari snorkel * 80mm RAW suspension lift * Custom Bull-bar * 33" MT tyres * 26Mhz & UHF CB units * West Coast Rust * And a partridge in a pear tree! Oh... and an awesome new Co-Pilot
