Hi Guys,
I have a '94 Nissan Terrano Turbo Diesel (auto). I'm not getting much power out of it and having lags between gear changes, do you have any suggestions as to the approach I should take to resolve these two issues.
I think the tank has history of the diesel bug (what is best to treat this with)?
Sorry for the basic questions, but I see that guys like dieselboy have great knowledge here on specific types so was wondering if you could help!
Thanks!
Severe Newbie Questions!
bugga
check the filter under the inlet banjo fitting on top of the injector pump u need a 17 mm spanner to undo it watch out 4 the 2 copper gaskets move fitting to side insert ball pen remove spring reinsert remove small filter blow clean n re install see if that fixs the prob
Terrano TD 2.7 and a ssangyong Rexton
