Help engine turns but doesnt start
Posted: Wed Feb 07, 2007 6:09 pm
by ToYoda
HELP
Truck turns over but does not start
No voltage at the glow plugs....
No light on the dash indicating heat but timer clicks
Prado 94 kz 3lt
Anyone got an idea...anyone..... anyone at all....
Posted: Wed Feb 07, 2007 9:03 pm
by DieselBoy
Sell it and use the money to make your Safari Kool :twisted:
You checked fuses???
Loose conections????
Posted: Wed Feb 07, 2007 9:29 pm
by ToYoda
Yes funny actually all three of the prados in the fuse box are missing the fuse labeled glow (glow plugs). So where is it. sounds the most logical choice but cant find any other fuse housing areas. Wire to the glow plugs appears fine but is not carrying current.
hmm....
And as for the safari i think its a bad week for my trucks as you know....gotta find the fluid leak...
Posted: Wed Feb 07, 2007 9:37 pm
by billyvanboheman
ToYoda wrote:And as for the safari I think it’s a bad week for my trucks
I know how you feel, early last week I had two Isuzu’s and a Honda in the drive, none of which was going!!!!
Sorry cant help with the glow plug problem, might be able to tomorrow after I talk to my Father, he may have a tip, he's been doing diesel work since Adam started riding horses!!
Re: Help engine turns but doesnt start
Posted: Thu Feb 08, 2007 1:37 am
by roscoFJ73
ToYoda wrote:HELP
Prado 94 kz 3lt
Do these have fusible links like the older landcruiser?
Its a piece of wire(s) close to the + battery terminal.
These also have a fuel cut solenoid on the fuel pump.If its working it should click as the ignition is energised on/off.
If it doesnt you can run a wire direct from the + battery ,to the solenoid.
The 1KZ motor should start without glow plugs if the solenoid is working,even in a Kiwi summer :D
Posted: Thu Feb 08, 2007 7:07 am
by wjw
roscoFJ73 wrote:The 1KZ motor should start without glow plugs if the solenoid is working,even in a Kiwi summer :D
If it won't pour a couple of pans worth of hot water over it...
Have a look through this:
http://www.wjw.co.uk/toyota/1kz/1kz-te.pdf
Toyota 1KZ Service manual,
Posted: Thu Feb 08, 2007 10:28 am
by gomulletgo
Join the club! :roll:
road vehicles my brother and I had going last week:
toyota hiace
road vehicles my brother and I did'nt have going last week:
toyota surf
nissan navara
toyota hiace
audi 80
valiant charger
Posted: Thu Feb 08, 2007 3:55 pm
by ToYoda
The silver metal box under the dash clicks after a couple of seconds after ignition is on
Posted: Thu Feb 08, 2007 6:03 pm
by roscoFJ73
I should have been more specific. The clicking will come from solenoid on the pump,the solenoid is a screw in thingy with a 2-3 wires connected to it.
There is also a tacho pick up there ,but thats is a the back of the pump.
The silver box clicking could be a ignition relay or glow plug but on other landcruisers they are usually on the inside fenders.
Posted: Thu Feb 08, 2007 7:13 pm
by billyvanboheman
Well I asked my Father, who has a diesel fuel injection w/shop while I was chatting to him on MSN tonight.
I copied the original post and sent it to him :)
The response I got wasn't what I expected........He suggested "take it to an Auto Electrician" :oops:
Posted: Thu Feb 08, 2007 7:35 pm
by 4wdnuts
before you take it to a auto sparky check all your earth wires. it maybe a long shott but i have trouble all the time with my hilux. especially after going thrrough some mud/ water or after bouncing around a bit.
clen the battery terminals and follow the earth wire back to where its bolted on the body. give it a good rub down with some emery paper to it has a good contact. rememberr toyota's like a good rrub down every now and then!
Posted: Fri Feb 09, 2007 12:09 pm
by Aaron
Crack open a fuel line at the injector and see if any fuel comes out, if not then check power to the fuel cutoff solenoid.
If you have fuel then it should go with a bit of encouragement :D
All a diesel needs is fuel, air and compression and it should go
Posted: Fri Feb 09, 2007 12:47 pm
by rollypolly
get a can of crc engine start
just joking,but it will start it, so long as ya got fuel
sounds like ya solenoid for the glow plugs is pocked,
Posted: Fri Feb 09, 2007 9:19 pm
by ToYoda
anyone know where the second lot of fuses is housed. i know theres some next to the pedals but there should be a second lot some where.
Posted: Fri Feb 09, 2007 9:25 pm
by rollypolly
CRC
Posted: Fri Feb 09, 2007 10:11 pm
by philux
under the bonnet, think they are on the drivers side
Posted: Sat Feb 10, 2007 11:29 pm
by ToYoda
There not the same place as a hulox or the 2.4 prado so where under the bonent??
