Toyota Surf 2.4 Turbo (2L-T)
Posted: Thu Feb 08, 2007 7:19 pm
by madaz068
I have a question re this truck with this engine. In the rev counter there is two lights, a red one and a green one, what does it mean when both are on all the time?
Posted: Sat Feb 10, 2007 8:56 pm
by gomulletgo
:boom: Na kidding. I really don't know. I did take a 2.4 turbo for a drive once and think I remember the red light means the turbo is sick +o(
Posted: Sat Feb 10, 2007 9:01 pm
by smurf182
Posted: Sat May 05, 2007 11:11 pm
by georgie_pph
red light means there is no pressure present in manifold ie no boost due to no load, green light means it is boosting. if both are going at same time it prob mean the sensor is faulty.
Posted: Sun May 06, 2007 10:21 am
by Petemcc
red light means over boost doesnt it? other wise when it was going well it would be on when ever the green one wasnt. this happend to my truck a year or so ago and i was told it was cos it was overboosting. had to get a new waste gate actuator was less than $100 for toyota to do it for me
Pete
Posted: Mon May 07, 2007 12:05 pm
by SupraLux
Pete is right - the orange LED means the turbo is overboosting. The green one means the turbo is boosting.
However normally when they are both on it means the 2 sensors on the side of the airbox are either faulty or disconnected... (at least I think thats where they are... been a while since I was under the hood of a 2LT truck...)
Steve
Posted: Fri May 11, 2007 6:56 pm
by NA_Drifter
emmm I got petrol engine in my Surf now which used to have 2LT in it. The orange light on mine stay constantly on and I haven't got a turbo!
Maybe due to missing sensor?? the green light stay off..
Re: Toyota Surf 2.4 Turbo (2L-T)
Posted: Thu Oct 18, 2007 7:45 pm
by hoddy2000
check the filter in your tank as that blocks up over time and the system starvs of fuel but noticable due to lack of power at same time???
Posted: Fri Nov 09, 2007 2:29 pm
by DIRTY74
yep would second steves comment orange is over boost. if both lights are coming on then its a faulty sensor or leaking vacum line. mate has 2lt with boost gauge is not over boostin but lights often change from orange to green and back again. fit a boost gauge. not sure if this sensor is tied into fueling or not?
Posted: Thu Jan 10, 2008 10:32 pm
by Hoelux
Yeah i agree. Mine does the same thing, seems to change from green to red at random times. Installed a boost guage and the turbo is still boosting all good. Apparently the lights/sensor go faulty quite often its just one of those things.
Posted: Fri Jan 11, 2008 7:14 pm
by tweake
Hoelux wrote:Yeah i agree. Mine does the same thing, seems to change from green to red at random times. Installed a boost guage and the turbo is still boosting all good. Apparently the lights/sensor go faulty quite often its just one of those things.
welcome to red light hell.
the red light is toyotas gneric "something is wrong" light. it can be several things from overboost to loose connectors. one that got me was when refitting the speedo consol some connector pins got a bit bent. it took a while to find that one.
if everything is working ok, if your running a 2LT (not a 2LT-E) you can disable the egr system, fit a hilux glow system then throw the whole ECU out.
or a poor mans fix, throw out the red light
