If I point my pinion at my t-case
brakes-shocks-lockers-etc
turoa
Pyro Junior
Post by turoa »
How much vibration will there be if I dont have a double cardon joint?
matwelli
Post by matwelli »
lots, if you are using U-joints, one U joint will be at 0 degrees (pinion end)and one will be at whatever the angle between the tcase and pinion is. This will cause the U-Joint to try to accelerate and decelerate every revolution. :(
Mathew - 021 441 043
