Weldable pipe caps for diff armour?
after "denting" the range rovers front diffhousing, I thought it may be a good idea to get some armour on the LandRover if I want to go playing on rocks again. So.... where can I get some weldable pipe caps? I figure its easier than beefing up a stock toyota housing, and it may be stronger aswell.
callum007 wrote:just buy one from the numerous places in OZ that sell them for like $160... im guessing a pipe cap gonna cost you similar....
Hell no, I got one from steel & tube for around $40 (IIRC, definitely not over $100) a while back. Of course you cut that in 1/2 & get both ends done. Never did get around to fitting it up to the Zook, might have to see if it'll go on the cruiser.
Just bending up & tacking on a heavy bit of flat to the centre of the bulge from the bottom to about 1/2 way up works pretty well too, thats where all the hits happen.
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
- rollypolly
- Driver/Navigator
I' ve bought some here in Hamilton off Cook and Galloway engineers ,they cost about $30 depending on diameter and thickness, these guys are making them for caping rollers , also look for any company that makes gas cylinders.
Your best bets to probally try some of the local engineering shops and just ask around, Brian Howat would be a good place to start.
