y60 alternater problems
For all Nissan related topics
Monty
Post by Monty »
ok so i went to drive the truck this morn because the alarm batt for the silvia is flat, so it just started voltage was about 22v seemed odd then it started and didn't shoot up to 26ish like it normally would so the alternator is stuffed who;s had this problem before and any ideas on what it is yes the belt is still there
yes i've been thru the waimak silt?
yes i've been thru mud holes
so yeah any ideas would be good
what are the brushes like on these alternators
thanks lee
I WISH I WAS A WINCH MASTER BUT I NEED A WINCH TO DO THAT
1991 safari with none of the boxes ticked im a fool!! SOLD
1996 nj paj 2.8td but with the diff lock box ticked :)
1978 DATSUN 180B sr20 POWERED
mud_slinger
Post by mud_slinger »
brushes dont like water i've gone thru many a set. check to see if ya got charge off the alt cos sometimes it is a fuse or relay that blows. if not pull alt apart and check brushes. a set of them cost like 8 bucks its the cheapest option
needs more curry
0272593533
Monty
Post by Monty »
thanks where do you suppose i get them from? just pulled it off this morning i'm guessing it was teh oil pump on the back of it?
thanks lee
alt
no it should be a vacum pump on the back of the alt
mud_slinger
i get my brushes from warren auto eletrical jus over 8 bucks.
needs more curry
0272593533
