Terrano starting problems
Posted: Mon Feb 19, 2007 7:56 am
Hi Guys,
I've got a '91 V6 Manual petrol Terrano that has had starting problems the day after visiting the local garage to get a steering rod changed.
When I first had problems I looked at the starter motor area and found a shiny new bolt on the solenoid, which said to suspicious old me they had problems in the garage. I thought that maybe I was being paranoid, and they didnt mention it, so I gave them the benefit of the doubt, didnt say anything and got them to change the brushes in the starter motor. Terrano worked for a day and stopped again. So I guess its more likely it is the solenoid after all.
A neighbour has suggested that maybe the solenoid got arced if they didnt remove the battery leads when doing the steering rod changed. Does that sound right? Am I being paranoid, or do you think the garage has stuffed up here?
I dont particularly like being taken for a ride, so may have a go at replacing the solenoid myself. But to change the solenoid, I have to remove the starter motor and replace the solenoid. Is that a big job - a big first job that is for a newbie Terrano owner? It looks very hard to get at, but is there anything I should be aware of when taking off the starter motor?
I have done various other jobs on other cars I have had, but nothing to do with the starter motor.
Any advice is really, really welcome!
Gay
Gay
