Oil Pressure and Temperature Senders
Posted: Mon Feb 26, 2007 1:31 pm
by wjw
Anyone got photos of:
Oil Pressure sender from 1KZ-TE or 2LT?
Temperature senders for same.
Need to get one of each, but don't know what they look like :(
Bill
Posted: Mon Feb 26, 2007 2:36 pm
by kaney
and where to find the oil pressure sender on the 2l-te
Posted: Mon Feb 26, 2007 8:06 pm
by wjw
I've found lots of senders in the 1KZ manual, but they only relate to the ECU, not the dash :-(
Posted: Tue Feb 27, 2007 8:07 pm
by mudhaw
kaney wrote:and where to find the oil pressure sender on the 2l-te
It is on the right hand side of the motor at the back nere the bottom.
It is a round cylinder with one wire going to it and it also has a joining plug up by the alternator wireing
Posted: Tue Feb 27, 2007 8:12 pm
by hosehustler
if you get stuck bill come round and have a look at mine, it's a 2L (non turbo) on the supra engine, swaps straight on :P
don't know if it reads right tho :lol:
Posted: Wed Feb 28, 2007 9:00 am
by wjw
I had a good look through the Tridon catalogue yesterday, almost all Toyota Diesels and some Toyota petrols use the same water temp sender and the same oil pressure switch/sender. So I've they are getting me a couple of oil pressure senders to check the thread. Then I can swap the switch out with a sender. From memory the following motors have the same senders..
2JZ-GE & GTE
7M & 5M
2LT, 22RE, 1KZ
They were just some of the ones I could remember....
The warning light on the oil sitch for all of them comes on at 0,2 Bar which is supprising ...
