Air Con Problem
Posted: Mon Feb 26, 2007 7:34 pm
by HernTheHunter
Hi Guys, just recently got my 1993 terrano 2.7 deisel turbo, Air con and vent position butons not working, its an auto air con system, fan works and cold/heat settings work but can not change from demist to cab or lower floor settings,no air con, no lights on switches checked fuse etc ok.....just thought I would check for Ideas before I start ripping out all panel work......... :?:
Posted: Thu Mar 01, 2007 4:49 pm
by disfordog
Mine is the same... Stuck on windscreen demist direction... I remember hunting around internet forums looking for an answer after checking all the fusees I could find and replacing the dash control unit to no avail...
:idea:
I recall reading somewhere that there is another relay in behind the glovebox. Remove the glovebox and replace thi relay with a working one and it should be problem solved...
I may eventually get around to pulling mine to see if it's repairable, or replace it....
I think the button lights is to do with a fuse inside the control unit because the lights worked on my replacement, but didn't solve direction issue...
Let us know how you get on...
Posted: Thu Mar 01, 2007 6:21 pm
by HernTheHunter
Thanks for that will let you know how I get on, will have to waite till fishing season over dont want to keep it of the road for to long.....
