just put in a uniden uh088sx model 40 chanel 18km range but want to know weather i should mount the arial on top of spare wheel carrier ????
or if u know a better place where im not going to rip it off wld b greatly appreciated???
just put in a uhf radio
nuts
- Location: somewhere arround westcoast offroading usually
nuts
arial
what if i mount it at the back on the spare wheel carrier?
does that affect it at all?
PRS is a Cb, its just Fm, not am. People still call them Cb.
Best place to mount ariel is somewhere with a good solid ground plan, (metal base)
Mounting to a steel bar is better than mounting to let say plastic, but its still not as good as mountng to a gaurd, or flat area of metal.
Ive got mine opposite my car radio ariel. Its been bent once, but I just straightened it up.
Also mounting it to a wheel rack etc can also shelter the ariel. This in turn will also shorten the range.
(18km will only be clear line of sight, in valleys etc, Im sure you'll still only get several hundred meters, which is to be expected)
Just mount it where it suits you, rear tyre carrier or what have you. It will still work, even if the range may be affected a little.
As for experience, I have a scanner aerial on the front guard of the truck, and one on the fiberglass roof of the carport (for when I take it in the shed when working in there) and the shed aerial works better, go figure!
I would however suggest you get a spring base for it, available from DSE etc.
Ph 0212078472
Ph 0212078472
u realy
It should realy be mounted in a pisition where it can get a good ground plane effect .
But in saying that the best place is middle of your roof totaly usless for our type of use main thing to rember is if mounted at the rear all or most of your signal strength wil be going out the front of your 4x4 and the reverse for front mounting it is realy a matter of its up to you and of cause some where so it wont get broke off to easy you could make up a DDRR antina and it would only b around 50 mm off your roof ? food for thought
Terrano TD 2.7 and a ssangyong Rexton
nuts
arial mount
thanx guys ... wound up bolting it on the bak door above the spare wheel mount works good there and well protected
