the truck in question is a 1992 3dr vitra 1600cc with ats
front end
front end
i have found that my front end is a bit low i think it maybe the sway bar that was catching on the rut as i am a chef alot of the tec talk goes stright over my head
so keep it simple please can anyone help with some kind of idea of what to do without major work to help with stop the front end catching things
- tomsoffroad
- Flopsie
i think its springs if we are on the same track it has coil springs and shocks all round but on further inspection the part of the under side that was catching on the ruts is of a y shape on each side of the truck on the front only the bottom of the y attached to the wheel and the other two ends to the chassi where it was catching on the ruts so i do feel that to overcome this prob i either need to do some major work raising the truck, not try to follow bigger trucks or save up for something bigger stronger taller with more power and with a larger footprint should do it
but this will have to wait till i have some more money
mabe a unimog if they are sole cheep or a project truck like a LR 90 or range rover
- tomsoffroad
- Flopsie
If you want to play with the big trucks then you gonna have to spend some dollars... The IFS is always going to be your limiting factor. There are plenty of lift kits available in the states if you want to spend the dollars...
http://www.puresuzuki.com/3_lift_kit.htm
But you might just be better off trading it in for a full size at the prices they are charging. I am not aware of anyone in NZ doing them.
Don't get me wrong - I am not knocking the Suzi's they are great little machines and can go along way.
The three position Lucas switch - Dim, Flicker and Off.http://home.off-road.com/~bodgerover/
If you want to find more modifying info search under Sidekick which is what they call a Vitara in the states....
