What size tyres can you fit on 15" rims?
dannyboy4949
Post by dannyboy4949 »
What is the largest tyre I could put on 15" rims? Also what would be a good size for these rims? At the moment the tuck is standard but Im looking into a 2" suspension lift and 2" spring lift
xj
Post by xj »
what width are your 15 inch rims....... some suggest 7 inch rims should only go to a max of 10.5 inch wide tyres...... some say 8 inch wide rims can take 12.5inch wide tyres..... even different tyre outlets seem to not be able to agree.......
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
15x8 rims a pretty standard for a medium + truck, tyre size is usually determined by the vehicle.... gaurd size and clearance and drive train to turn the wheels
xj
Post by xj »
.... so sadam, you would put what width tyre on a, say, 7 inch rim then? 12.5 inches wide perhaps? no drama to sidewalls on a tyre that wide with a rim that narrow?
I have seen guys driving exactly those dimensions with no care in the world, but go and suggest that to a tyre shop....
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
Mattman
Post by Mattman »
I have 33x12.5x15's on my 15x8 rims with no probs however I do have a set of 15x10's ready to go on at some stage.
Matt.
[quote="xj"].... so sadam, you would put what width tyre on a, say, 7 inch rim then? 12.5 inches wide perhaps? no drama to sidewalls on a tyre that wide with a rim that narrow?
quote]
I've never had a 7 inch rim so I dunno what does and dosent fit on them? I guess if the eye-ometer says the tyres dont look right then they arent?
I've had 33x12.5 and 35x10.5 fitting nicely on 8 inch rims
Smurf
Post by Smurf »
I have two sets of 33/12.50/15 tyres on 8 inch rims.
Mates are running their 12.50 Hankook tyres on factory rims, but Hankook recommend that their RT01 4wd tyres are fitted to a 10 inch rim though.
xj
Post by xj »
And so, harking back to the initial response....... Dannyboy, what width are your 15 inch rims? :wink:
If we know what width they are, we can then have a starting point to wax lyrical about the plusses and minuses of side wall stress, excessive roll over of perhaps rims being too narrow etc etc.....
:D
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
Return to “Tyres”
