Factory rear "Locking Diff" in LJ71 Landcruiser
Hi all, wondering if someone can help me here.
I've just purchased a '91 SWB LJ71 for a bit more serious off roading than the family LWB Pajero allows me.
My cruiser has a G144 rear diff, at least that's what the build plate says and my research indicates the G = 8" ring gear, 14 = 4.875 ring/pinion gear ratio, and the last 4 = 4 spiders and Locking Diff.
My question is, and please excuse me if it's been asked many times before (I did search all 10 pages of the Toyota section), how do I lock the "Locking Diff"? There are no buttons to push. Perhaps it locks automatically in 4L, but would like this confirming.
Cheers for any help.
- IcedJohnno
- Trailer Trash
If your truck has the electric locker like some of the KZJ-71's and 78's there will be a rotating switch near your left knee when seated behind the wheel. It is between the heater controls and the steering column.
The switch lies horizontal when disengaged and has Difflock written on the knob and off-push-on written on the switch housing. Rotation of it 90 degrees
gets a red light flashing in your instrument cluster which should stay on permanantly when the difflock engages. My elocker engages properly but the contacts are dirty and the light stays flashing.
cheers John
cheers John
Thanks for your responses. Definitely no switch to lock it.
I've found conflicting information about what I thought originally.
The axle code G144... the 4 on the end means open diff and locker, but the locker appears to have been optional extra.
At least now I know why I got stuck coming out of a "not so difficult" water crossing on the weekend.
Highway wrote: At least now I know why I got stuck coming out of a "not so difficult" water crossing on the weekend.
Just to possibly eliminate another question - where was it you got stuck??
Baldrick
91 Cruiser VX Ltd Auto Diesel Turbo *Safari snorkel * 80mm RAW suspension lift * Custom Bull-bar * 33" MT tyres * 26Mhz & UHF CB units * West Coast Rust * And a partridge in a pear tree! Oh... and an awesome new Co-Pilot
oldblue wrote:Just thinking about this, do you have electric hubs?
Its quite common for a Prado that has done more than 100,000kms to have one of the hubs not engauge sometimes
Yes those damn electric hubs. They are on the list for replacement with manual ones.
What's the easiest way to tell if they're working or not?... other than getting myself stuck.
Baldrick wrote:Highway wrote: At least now I know why I got stuck coming out of a "not so difficult" water crossing on the weekend.
To avoid further embarassment I'd rather not say
- IcedJohnno
- Trailer Trash
[quote="Highway"][
Why Damn electric hubs? They are stronger than any after market version and some like me find the ease of use great.
I know eventually I shall catch the wires on a ball of ice thrown up from my chains or a stick in some mud or something but I find them great. I have bent the wire mounts further inwards to minimise this happening
My plan is to get OldBlue to do both a manual and electric conversion on them at some point. This way I can still push the button but if the wires break or the brushes fail I can still wind them in on the allen key.
Test by engaging hubs and putting in 4wd. Put in gear but leave the motor off! Next jack up one front wheel in turn and try to revolve it. If the hubs are working the wheels wont be able to revolve cos the diff wont work cos the other wheel is still on the ground and the driveshaft can't rotate cos the transmission is engaged.
cheers John
cheers John
Highway wrote: To avoid further embarassment I'd rather not say. But will say I was grateful to the Safari owner for a tow.
No worries - the "culprit" for a similar event has owned up elsewhere. Pleased you got out ok.
Baldrick
I wasn't wanting to offend anyone by calling them "damn electric hubs". Everything I've read about them say's... and I don't remeber the quote verbatim but, "not if, but when they fail". I also acknowledge that they're regarded as stronger that any aftermarkets.
Being a wheelchair user I certainly find the convienence of not having to get out of the drivers seat unbeatable. But reliablility is also a factor.
Electric and manual conversion? Now that sounds like a great idea.
Will this work with an auto tranny?
Cheers for your help.
IcedJohnno wrote:Test by engaging hubs and putting in 4wd. Put in gear but leave the motor off! Next jack up one front wheel in turn and try to revolve it. If the hubs are working the wheels wont be able to revolve cos the diff wont work cos the other wheel is still on the ground and the driveshaft can't rotate cos the transmission is engaged.cheers John
Thanks for that John.
I've given that a try, having an auto I tried both Park and Drive... front wheels spun nice and freely... unfortunantly...so I will assume the hubs aren't engaging as they should.
