Drag link reinforcing?
Posted: Thu Mar 15, 2007 8:31 am
by DaveM
Has anyone reinforced their safari draglink? Although its the first time I've damaged mine, if I plan to head out again with Al and Rik (which may not be a good idea anyway) then I think I should make it a little stronger.
Posted: Thu Mar 15, 2007 8:39 am
by doddzee
I bent the one in my dads truck in december, pulled it straight with the winch and weleded a peice of 20x20 angle down its length. Seems to have done the truck.
Posted: Thu Mar 15, 2007 8:50 am
by DaveM
Thanks, couldn't get mine off to straighten so used the sabresaw and now have 2
Will do the same to strentghen mine.
By the way, when is the ute ready? Can't wait to see it in action........
Posted: Thu Mar 15, 2007 9:00 am
by doddzee
DaveM wrote:By the way, when is the ute ready? Can't wait to see it in action........
I keep asking the same question.
Id like to see it in action as well.
Posted: Thu Mar 15, 2007 11:42 am
by Dak
I recently replaced the tie rod, the one behind the diff, with a Howat Engineering jobbie as I bent the hell out of the factory one, I plan to leave the drag link as is though, I'd rather have that as a weak point than break something else.
Cheers, Jeff.
Posted: Thu Mar 15, 2007 11:46 am
by DaveM
Tie rod on mine has had it too. Did you have to supply your old tie rod to Brian to mod, or was it a complete new one?
Posted: Thu Mar 15, 2007 11:56 am
by Dak
Complete new one with GU tie rod ends.
Cheers, Jeff.
Posted: Thu Mar 15, 2007 11:57 am
by DaveM
hmmm, that sounds good. Any idea on price?
Posted: Thu Mar 15, 2007 5:08 pm
by Dak
Are you sitting down?
$550 odd, which I think in reality is way to expensive, It's made out of solid chromoly which I know is expensive but when you can buy the same thing in Oz for $330 something ain't right.
Cheers, Jeff.
Posted: Thu Mar 15, 2007 5:12 pm
by DaveM
Dak wrote:Are you sitting down?
Cheers, Jeff.
Holy smokes
I think I will just reinforce the $50 replacement I have here to save a little money.
Posted: Fri Mar 16, 2007 2:39 pm
by GQTROL
Use a length of solid and a pair of female tie-rod ends. The rod ends are about $125 each from Nissan, I've posted the part numbers here before (LH and RH have different part numbers).
