Currently my escudo has rear drums and i would like to upgrade to discs to get more bits out if my fiddle brakes. Do any early vitaras have rear discs?
Anybody converted the rear to disc's that can point me in the right direction?
Escudo Rear Disc Brake Conversion
MWB V8 Safari Ute
- PuddleJumper
Re: Escudo Rear Disc Brake Conversion
Anyone mking a bolt on set of brackets yet? Seems like a small but definate market there.
I'll buy a set of brackets for sure. Actually need them sooner than later.
Yeah I know this is a bit of an old thread. Been digging and it came up.
Found on another site
might have found another option, Suzuki and said to be bolt in ...
Off of a Suzuki swift GTI, rear Kick/Vit discs, machined back to 240 mm's instead of 290 mm (9 1/4 inch instead of 11 1/4 inch). thickness is the same. If you get the calliper mount off off the swift it would bolt right on (still have to try this). But I'm about to order the parts from the Junkyard and see how it turns out.....
Big-Al has discs on the rear of his 413 (were done when he got it), I'm sure he'd be happy to show you the truck if it helps.
Truck is in silverdale...
