1993 Mitsubishi Pajero SWB V6
nzelfy
Newbie
Newbie
Post by nzelfy »
My parents just brought me a 93 pajero. Can you give me advice on things i should watch out for and any cheap mods that can be done to improve on and off road preformance with out hurting fuel economy.
doddzee
Is Doddgee
Post by doddzee »
Being a 3.0 V6 your fuel economy will already be hurting. The V6's are fairly bullet proof untill you start chucking bigger tyres and lift them then you start running the riskes for bending steering components and blowing Cv's. Did yours come with a factory rear locker?
Have a look through NJV6's project thread lots of good information in there about making your pajero perform better off road.
http://www.offroadexpress.co.nz/modules ... pic&t=2159
MWB V8 Safari Ute
northland_pajero
Post by northland_pajero »
I have a 94 2.8 diesel, with a now dented fuel tank and now a 4 mm steel protector for the tank, wish I had done that before I started playing
matwelli
Post by matwelli »
definately check out NJV6's thread.
Cheap mods...
Remove sway bars (your choice, I have, the on-road handling suffers)
Cut front upper and lower bump stops in half.
Crank front torsion bars untill truck sits level (most seem to sit low in the front)
The reason for the above to get get the truck to flex
You can crank the front sway torsion bars a bit more for an extra 2 inches of lift and swap the rear springs for some out of a Nissan GQ patrol. This will hurt the amount of flex you can get.
The CV's are pretty stong, dont worry about them.
Mine still sits at standard ride height, and runs a set of 33 inch mud tyres
Mathew - 021 441 043
NJV6
Post by NJV6 »
Reading my report is inspiring an update!! 8)
If it is a 3.0 then putting Pootrol or Safari springs in the back may lead to vibrations due to short rear driveshaft length.
NJ
