Will a Toyota winch work???????
For all Nissan related topics
DaveM
Post by DaveM »
Just out of interest, is it possibe to easily adapt a Toyota Pto winch to fit a Safari?
Much more toyota winches available out there............
doddzee
Is Doddgee
Post by doddzee »
Dont bother they run a 4mm shear pin and you will break it all the time. Stick with the nissan. :wink:
MWB V8 Safari Ute
safari_mulisha
Post by safari_mulisha »
allready thought about it....
pretty much same answer as doddzee
GQTROL
Re: Will a Toyota winch work???????
Post by GQTROL »
DaveM wrote:Just out of interest, is it possibe to easily adapt a Toyota Pto winch to fit a Safari?
Strictly speaking, yes you can. You just wont be able to use the winch mounting points on a factory Nissan winch bar though. I've also seen a Nissan PTO winch on a Toyota FRP top Landcruiser, so they swap back the other way easy enough too.
Toyota PTO's do seem to be alot easier to come by on TradeMe etc compared to the Nissan ones.
4WDbits
Post by 4WDbits »
I was under the impression (maybe false) that the Toyota PTO was less likely to break a drum or through the worm drive into the mud. Someone please correct me???
DieselBoy
Post by DieselBoy »
Think the majority of Toyota PTO's are cast iron/steel housings as opposed to Nissans cast alloy housings.
That would mean the Toyota housings are potentially stronger and less likely to spit them into the mud.
mercutio
Post by mercutio »
i have heard a rumor that the alloy safari winches sometimes let the worm drive screw themselves out of the housing
i also heard that some of the winch challenge guys running safaris with a PTO winch use toyota winches to get around that issue
but don´t quote me on that :lol: :lol:
my 4wd is not a truck
DieselBoy
Post by DieselBoy »
dazza85
Post by dazza85 »
GQTROL
Post by GQTROL »
So far there is one Nissan comp truck (Kev and Troy) running a Toyota PTO...simply because they could get a cheaper supply of them than the Nissan ones.
If you load it up enough (i.e don't run a shear pin), the gear housing on Toyota PTO will still let go as the worm drive goes out the bottom of it.
