94 Surf Tailgate Motor
Posted: Wed Apr 11, 2007 1:34 pm
by PAID
Kia Ora Koutou
the back window in the Surf has finally given up.. stopped working with the in-cab switch a few months ago, but has recently stopped working with the key as well
i assume it's stuffed at the cab switch and the motor.. that said, anyone have a source for a replacement motor? have been told also, that the cab switch gives up a lot.. so looking for one of those as well
thanx in advance for any help given
Posted: Wed Apr 11, 2007 7:52 pm
by Mattman
You can often spray contact cleaner on the cab switch and get them to work again, you might be lucky.
Whenever I come across a Surf being parted out I grab the rear window switch....
Unusual for the key to fail as well, they are very simple mechanism's and easy to get out and test.
If you have a multimeter you can test it quite easily. With the window up from inside the truck pull off the carpet panel and remove the metal liner. There is a spring clip that holds the lock in place and a plug nearby to disconnect the wiring.
Check the continuity of the key wiring first before doing anything else, it could well be the rear window wiper or window switches making the truck think it shouldn't allow the window to be wound down.
Matt.
Posted: Wed Apr 11, 2007 9:38 pm
by tallsam66
Possibly the rear window relays may have blown up.
I read this the other day...check it out.
http://www.toyotasurf.asn.au/techsite/rearwindow.htm
good luck
Posted: Wed Apr 11, 2007 9:40 pm
by tallsam66
just found this..
check it out.
http://www.4crawler.com/4x4/CheapTricks ... ndow.shtml
trev
Posted: Wed Apr 11, 2007 10:24 pm
by PAID
thanx guys.. i'll have a good look after work tomorrow
the reason i suspect the motor is gone though, is because when i turn the key i can hear a click.. just no movement.. so i assume the relay is still working. it's not a mechanical click.. it's an electrical click.. if that makes sense
i'll dig my multimeter out and track the fault
thanx for your help guys, it's given me a place to start
keep the ideas rolling
Posted: Wed Apr 11, 2007 10:27 pm
by dazza85
Hey Trev,
The link doesn't work :cry: :cry:
Posted: Thu Apr 12, 2007 5:49 pm
by warpphead
i have got working motor out of a LN130 surf if your intrested
Posted: Thu Apr 12, 2007 6:08 pm
by tallsam66
strange ...both links work for me..does anyone else have problems with them????
Posted: Thu Apr 12, 2007 10:14 pm
by PAID
warpphead wrote:i have got working motor out of a LN130 surf if your intrested
yeah mate.. what year and how much?
dont spose you've got the in-cab switch as well?
tallsam66 wrote:strange ...both links work for me..does anyone else have problems with them????
worked fine for me
