I have an oil pressure gauge in my dash that reads nothing. Reason for that is it isn't actaully connected to the oil pressure sender.
Now I've found the plug that connects a wire to the sender.
But I don't have the wire that plugs into this connector and then to the sender.
Fooling around lastnight I found if I stuck a piece of wire into the correct connection on the connector and then earthed it I could make the oil pressure gauge go all the way up to max. Yes!!! I thought at least the gauge works.
Then I thought just connect this wire to the oil pressure sender and fire the engine up and I'd have a working oil pressure gauge.
But no. All I can achieve is having the needle on the oil pressure gauge move slightly.
So either I'm missing something or I have next to no oil pressure. But then the engine has run for a couple of weeks without seizing.
Questions I haven't answered yet:
1.) the oil pressure sender might be the wrong one or faulty
2.) Why does the plug that connects the wire/s to the sender have two connections? I sense this might be important
This is the only gauge I haven't got working in the dash so would like to sort it, but it's irritating me to the point where I'll be done with it and install a mechanical gauge.
As always any help would be appreciated. Cheers.
