cheap vitara lift
cheap vitara lift
finally got my springs sorted in my scudo ,put c33 laurel rear springs in back and vn commodore rear springs in front got 2inches of lift in front and back and still nice and soft so i have lost no compression.laurel springs are perfect fit, holden ones are slightly bigger overall diameter
but no problems . i will put pics on soon. manual hubs to go on this week as blew a hub last weekend.
vaughan
vaughan
- warlord225
- warlord225
just put some LWB vitara spring in mine, with the front strut tops fliped and some ea falcon shocks, in the back.
you will need to chop the ends off the lower eyes cause they are too wide, the will only give you about 30mm extra down, but with the strut flip and LWB springs I picked up about 2 or 3 inches extra travel plus the 2 inch's or so ride height
the springs set me back $150 from te puke parts world with everything included, I can't tell you how much the shocks cost me, cause it cheaper than trade prices.
old man emu front shocks are next on the list as is a
6 point from calmini ($850)
the the exhaust again from calmini ($650)
and the rear locker again from calmini ($450)
650 for a exhaust is a bit steep isnt it? . how much lift did you gain at front with the lwb springs , i bought a whole lwb with no motor or box for 100 bucks off trade me so i was curious to try front springs on mine compared to commodore ones, it was that camo gem from mudbits but gave me spare diffs for mine and chassis and body for new toy once shortened a bit. have a few spare bits if you need , cheers
vaughan
vaughan
- warlord225
- possumslayer
- Stropper
strut top flip
will someone explain the strut flip. its for a mate of mine.
- SuzukiDeano
- Stropper
possumslayer wrote:Hi
Have done as spanky said and put c33 laurel springs in rear + vk wagon shocks and used vl commy springs in front and did a strut top flip on the escudo.
Also put some 30 inch tires on and gained some good ground clearance.
Everything seems to be sweet as so far.
Will put up some pics soon.
What shocks did you use in the rear? Standard or something else?
- Rotazuk
Strut flip .
On the front of the vitara the shocks do not make full compression by about 2 " I believe . The top of the strut is bolted to the mount by a hat setion plate . By flipping the plate the top mount of the strut ( shock ) is moved down about 35mm . This allows more down travel and does not affect up travel as the strut never bottomed out .
Hope that makes sence , otherwise just come around and look at one done in the shed
the strut flip is a good way of getting a bit more movement for free and as rotazuk says it doesnt affect the compression, you can see in these photos if you look at the front how much travel you gain ,would look better if i had front guards. as it sits now commodore vn rear springs in front with std 5dr struts and back is c33 laurel springs with aftermarket commodore air shocks , and no sway bar, and you could just about get sea sick on a windy road it moves so much but is great off road
if you go much higher in the front you will start breaking cvs, i am trying a few different springs in the front now as with the winch and bar i have put about 50kgs right on the nose, cheers
vaughan
vaughan
vitara lift
thanks for that will be a great help for my mate, he tried making spring packers for it but has not worked out as well as he hoped ,
hi there zeuszuki, the ea springs are really good but i am putting in a pair unchopped to get even more clearence and then i will get some better pics, i dont know how much i gained in height but mine has a bit of weight right on the front and now you dont notice it being lower than the back like it used too
if you have broadband watch this for a laugh
http://www.offroadexpress.co.nz/images/albums/album283/100_1967.mov
if you want to do this pm your email and i can send pics of how they fit .
cheers vaughan
cheers vaughan
ToyRover wrote:how hard is it to fit the springs in is it much trouble at all
The rear is real easy...
The front is a pain the first time but gets easier and much quicker in subsequent times...
Spanky probably has a better way of doing it but i found it really fiddly once i had undone the 3 bolts on the ball joint bracket and was trying to clear it from the lower arm..
what year vn springs
hi there guys i seen you have lifted the front of your suzuki with commy vn rear springs i have a suzuki 1991 escudo and i am wanting to do the the same just wanting to know what year vn was it and will they fit in mine with no hitchs thanks
- possumslayer
- Stropper
- suzuki_mike
- Driver/Navigator
- possumslayer
- Stropper
been mucking around some more and tryed it on one of my ramps at work, now has ea falcon with 2 1/4 coils cut off no sway bar ,still running laurel rear springs and commodore air shocks.made a spacer for the top mount on the rear diff which i will try tomorrow and see if that helps in the back ,the ramp is 620mm high .
vaughan
vaughan
