Might ruffle a few feathers but under my tyre has to be the best place for a Holden Commodore
The pic's a bit dark, but is that daylight between the rear springs and the upper carriers ?? I thought that was a no go for cert ??
I hear they were a bit long, even after I'd shortened them, I'm going to make the next set shorter and I'm going to put two bolts through to the king pin key(save having to use the shim to locate the key), any other ideas???
Cheers Reece
SupraLux
Posted: Tue Oct 26, 2004 5:18 pm
The word I got from the certifier was that 10mm is the max you can get a cert for with a spacer, but if you use the bolt on ones you can go up to 27mm... any more than that and no certificate...
SupraLux
Posted: Wed Oct 27, 2004 5:00 am
I'm having some 25mm bolt-on spacers machined up. I'm going to remove the IFS disc and calipers since it seems they won't get certified with the pads not fully contacting the disc - I'm going to use FJ40 discs and the IFS calipers with the 25mm spacer for the front
regards
Steve
SupraLux
Posted: Fri Oct 29, 2004 4:31 am
My Nana gave you free wheel spacers?
Bubba
Posted: Fri Oct 29, 2004 12:58 pm
So OK I think I have established I'm a dumb ass But what do spacers do?
