Toyota 14B , H55J for a landcruiser for quick sale
adventures_more
Post by adventures_more »
Ok , i was gettn ready for a performance build for my SWB landcruiser , but previous debts have held me back from moving forward , so have decided to sell the parts for my build & move back to Aussie to rectify my situation & get back on track , plus having hassles with landlord as am renting and am very eager to move out asap ( live in CHCH ). so these are the parts fot sale cheap >>>
Toyota 14B diesel engine ( 3.66 ltr ) , come with a factory Diahatsu 14B worskop manual ( hard to get ) ,its missing alternator & starter but injection pump and most everything else is there , its a rebuilder as the pistons are scuffed ,the crank , rods are in VGC and the head is being crack tested ( was my start of the build ) or has been - just have to pick it up , i was going to sleeve the block out to 15B size ( 4.1 or 6mm bigger bore and as far as i can make it ,the only main difference between a 14B crank & 13BT, is the 14B crank mains diameter is like 1-2mm thicker/wider , perfect candidate for a stroked 13BT, by just machining the crank down )
* H55J 5 speed landcruiser gearbox in GC to suit the H series diesel engine , comes with the bellbousing & fork to suit , been cleaned inside & out . ( have a VGC transfer with PTO , but may use this in my 4x4 - so not included )
All this for $500 and its yours , won't seperate unless you go in a group buy , etc
adventures_more@yahoo.com
MOB : 021 147 3212
Rick
http://i12.photobucket.com/albums/a215/ ... 040022.jpg
http://i12.photobucket.com/albums/a215/ ... 040020.jpg
http://i12.photobucket.com/albums/a215/ ... 040017.jpg
http://i12.photobucket.com/albums/a215/ ... 040014.jpg
