leaf springs???
For all Suzuki related topics
Ryan
leaf springs???
Post by Ryan »
ok spent today cleaning under my new 413(grotty job) and the springs
are flat as, if not bending the other way......
is there anyone out there who has put springs from another vehical in to
replace them or any sugestions would be appreciated :?
Dr_PC
Re: leaf springs???
Post by Dr_PC »
Ryan wrote:ok spent today cleaning under my new 413(grotty job) and the springs
I replaced mine with a complete set of Tough dog with nolathane bushes, greasable shankles and the biggest shocks that I could fit cosy in excess of 2500 but the best money I ever spent on my 413, It did take about 12 months before the springs settled in and evertything started working well
Dr_PC
Re: leaf springs???
Post by Dr_PC »
You could always pull them out and beat them back up
Ryan
Post by Ryan »
that may be what ill do cause $2500 is way beyond my budget..... :lol:
Dr_PC
Post by Dr_PC »
Ryan wrote:that may be what ill do cause $2500 is way beyond my budget..... :lol:
I tried 2 sets of Springs from Archers but didnt have a good run with them couldnt get them to last longer than 12 months before flattening , could well ne my driving style tho as other Zuk drivers seem to go okay, I also had more luck with beating up the original Zuks spring than others apart from my Tough dogs which 3 years later are still going well
Beat them back into shape using a good hammer around 4lb on a hunk of railway iron is what I first did. Getting aftermarket spring retensioned dosnt seem to last long
SupraLux
Complete Bastard
Post by SupraLux »
I think the Maxitrac ones (50mm lifted) are around $450 a set of 4, and long travel shocks are about the same again (roughly, from memory...)
Steve
Ryan
Post by Ryan »
cheers steve..... 8)
Cloggy_NZ
Texas Chainsaw
Post by Cloggy_NZ »
Dr_PC wrote:Beat them back into shape using a good hammer around 4lb on a hunk of railway iron is what I first did. Getting aftermarket spring retensioned dosnt seem to last long
Yes I have read that somewhere.
You need to take the leaves apart and trace around them with a piece of chalk on the garage floor so you can see how much you are reshaping them and to get both sides the same.
Sounds like a noisy job though, hope the neighbours like you :lol:
Ryan
Post by Ryan »
i think the thing to do would be to put them in the press at th engineers next to my work..... :wink: nice and quiet and no need to work up a sweat either....
Ryan wrote:i think the thing to do would be to put them in the press at th engineers next to my work..... :wink: nice and quiet and no need to work up a sweat either....
My mate did that with some cruiser springs at southwards a few years ago :o
must of done the trick coz he never mentioned any problems with them
Ryan
Post by Ryan »
well the engineers arent keen on useing the press to rebend the springs and im not keen on the hammer idea... i priced retentioning and thats about the same price as maxitracs, but was talking to a mate today and he says new springs are to rigid and take ages to come right because of the weight of the zuk puts bugger all presure on them???....
any other ideas (other than coil overs)
Cloggy_NZ
Texas Chainsaw
Post by Cloggy_NZ »
Ryan wrote:any other ideas (other than coil overs)
A good set of second hand ones would be the way to go then.
Ryan
Post by Ryan »
ill do that right now cloggy..... duh the one thing i didnt think off haha
mroffroader
Post by mroffroader »
Ryan wrote:ill do that right now cloggy..... duh the one thing i didnt think off haha
for the minute take jamies shackles off his hands. And fit 30" muddies. you will find that these will scrape every where but it will be ok untill you get some money for lift springs. Jamie bought lift spring off trademe for very reasonable $$$ :wink:
Ryan
Post by Ryan »
im gona borrow his shackles dude, already sorted,got new 30x9.5s with it and no it wont scrape when ive finished cutting my little freind.......
mroffroader
Ryan wrote:im gona borrow his shackles dude, already sorted,got new 30x9.5s with it and no it wont scrape when ive finished cutting my little freind.......
No the shackles will scrape on everything....llthats why jamie got lift springs so that the shackles were up out of the way :wink:
icekayak
Post by icekayak »
otherwise keep an eye out on repco for maxitrak...
they had springs (roughly 2" lift) for $75 each or something a while back... or if you happen to know anyone that works there may be able to hook you up at decent trade price...
mroffroader
icekayak wrote:otherwise keep an eye out on repco for maxitrak...
if that is the case i have a repco cash card ryan if you need it for that purpose.....save u a bit of moolah :wink:
Ryan
Post by Ryan »
i have the dollars mr0 but have been warned of new springs by a couple off people now saying they could be to rigid??
mroffroader
so you'd rather spend it than get some money back??? sounds silly? :?
Ryan
Post by Ryan »
what are u on mr0????
i dont think u understand?? i have the cash and access to a repco card
i jst dont wana waste my cash on springs that are gona make my zuk a
lifted brick on wheels!!!
icekayak
Post by icekayak »
yeh unfortunately there isn't too many other options other than new springs if you wanna lift it... seems to depend on who you ask and what you end up gettin on how it handles...
shackles can make it wander over the road, and decrease the approach angle... have heard BAD things about gettin them reset and they just sag soon after... so unless you can find some 2nd hand lifted ones :(
Just drive it hard and put a bit of extra weight in it and they should soften up soonish (well that's what i'm planning on doing)... I've gone with maxitrak springs, toughdog bushes, and planning on getting shocks once i've measured it all up...
Oh and a cash card doesn't save that much off the springs :( need a decent trade account/know someone/decent special and you can get them heaps cheaper.. (their normally about $115 from memory)
Ryan
Post by Ryan »
thanks icekayak you understand what im on about ....... i can get trade discount from work so i think thats what i may have to do.......
icekayak
Post by icekayak »
yeh have been in your position a few months ago... and it seemed like the best compromise for me between price and lift etc...
unfortunately my truck has been put on hold for a while with uni and that :(
front springs are fitted but its still on blocks so can't tell you how much it has been lifted or what their like... but planning a decent virtual lift and have got 31's to put on it, but hoping to go upto like a 32x9.5 simex or something (which actually measure 33)... will have to move the front diff forward a touch and knock the firewall back a little
Steve_t647
Post by Steve_t647 »
In the US they have been putting the rears in the front and Toyota Hilux front's on the back. Havent seen anyone here or in aussie saying they have this setup but it is another option.
As far as extra weight goes you can load your zuk up with water (saves lifting just fill several chilly bin's in place) to speed the process but they will still take a little bit to free up. or you can as someone I know did unpack the new springs and minus 3 leaves for 3 weeks then when they started getting flat add the rest back. Have no idea how long those springs will last...
redzuki
Post by redzuki »
I used to run lift shackels but i found they got hung up on things sometimes and it was a little worse to drive on the road but they are a good start while looking for lift spring and you can easily take them out.
Then i found a set of 2 inch lift springs on trademe for $300 they made my zuk heaps better off and on road ,but i found they were a little stiff so i took a leaf out and they are ok now, and like the others say i have been told re-tensioned springs sag after a while so they may not be the best solution.
Hope this helps
Steve_t647
Reset springs sag after a while and they can only be reset about 3 times before they become useless aparently (sag really quick)
Reset springs are usualy not as stiff as new and flex better but you get what you pay for.
Oh for that lotto win..... :?
toysuzi
Post by toysuzi »
how about a body lift 1 to 2"
a few in nelson are running 31" with just a body lift
toysuzi:(SJ413) 3Y E surf engnie, 6" coil kit (RRO). toy diffs (4.88 R&P) & toy hilux box and t-case.
ifs toy power steering, 6" Bushwacker fender flares (RRO). ect
gazzuk
Post by gazzuk »
posted this on the other thread but anyway... ST90 van springs bolt in the back, about 2" lift and usually brioken in by the time you get them. Extra leaf but you can chuck the overload (I haven't as it totally stops rubbing). Can also canabalise these for extra (stronger) leaves for the front.
Return to “Suzuki”
