Hi
i am looking for shops that sell lift kits i am in chch and i looked in the yellow pages and the only place that sells them are KATS which are quite expensive
LIFT KITS
- tomsoffroad
- Flopsie
92 Toyota Hilux Surf Wide body these are the pricesfrom kats
"92 Surf should be LN130 chassis number?
New rear coil springs $230.00 pair
New shocks front or rear - Monroe Adventurers $240.00 pair - Rancho Adjustables $400.00 pair.
Adjust front ride height and wheel alignment $75.00
Fitting of springs and shocks $100.00.
Heights limited by front bump stops usually 30-50mm. Exceeding this is hard on all steering parts and cv joints etc.
Ring Tony for more info (03) 327 6930 between 8.00 - 5.00 pm or Toll Free 0800 80 5287 and ask to be transferred to Tony at Shock Shop.
Thanks.
Tony.
----- Original Message -----
Thanks.
Tony.
Re: LIFT KITS
try delta 4wd parts ferry roadAnonymous wrote:Hi
What exactly are you going to use the truck for? Give me a call on 021 637 600 (I'm out of town) and come down to the shed for a look at what you can do with them. What sort of equipment you put in depends on what you want to achieve, so a little more information would be good...
I'll be back in Chch on Tuesday night.
regards
Steve
http://www.4wdstuff.co.nz
regards
Steve
