Hi
Ok I am a bit slow . opened a new album for some pic's and it wants me to edit the name etc but I can't . I can hide it etc . What am I doing wrong , will be simple know doubt .
Chris
Editing album name
- mike
- Last minute Mike
It is abit confusing the way they have the album name not actually changing the title of the album.
Help section on the albums.
http://www.offroadexpress.co.nz/modules.php?name=FAQ&myfaq=yes&id_cat=6&categories=Gallery+Help
If you are inside your album, then click properties and change album title. If you are where everyone elses albums are, but on your page, then click edit title .
Hope this helps.
Mike
Hope this helps.
Mike
- Rotazuk
Hi
I read the help last night but no help . I create a new album from the pull down admin options menu etc . But it will not let me do anything else .
I do not see a properties option except under admin etc and it won't let me do anything with it .
Off to work , will have a look again after work
Chris
Chris
- mike
- Last minute Mike
Hi Chris,
Have another crack, if it still won't work for you just PM the title to me and send the pics to mike@ore.co.nz and I'll put them up
Mike
Mike
- Rotazuk
Hi
Getting there . Seems I can only do one action at a time , ie create album then I have to close explorer and re start it then I can do another . Each time I restart the menu seems to change .
Out of time last night so try again tonight . Have loaded one photo but until I get the name thing sorted will wait .
Also it sees I created two albums the other night and can't see anywhere to delete it . Can you delete the other album I created with nothing in it ?
Chris
Chris
- mike
- Last minute Mike
I'll delete those albums no worries at all.
also if IE has given up on you try using this small browser. http://www.mozilla.org/products/firefox/
Mike
Mike
