Page 1 of 2
toyota 5m-ge engine
Posted: Mon Nov 01, 2004 8:57 pm
by pinky
hi all have just finished a supra to surf swap and SAS and rear spring swap but for some reason the engine has thrown a wobbly and now runs like a pice of shit so i need a complete engine manual . and i know what you all are going to say but the toyota dealer in timaru do not have this manual so can any one help with sourcing a manual thanks . :(
Posted: Tue Nov 02, 2004 7:13 pm
by DJ
the engine has thrown a wobbly and now runs like a pice of shit :shock: :shock:
hi
no Toyota runs like shit they just have good and bad days.Workshop manuals are hard to come by it sounds like you may have done something wrong on installation................soooooo tell the group your problems and im sure some one will get it right. Not much can go wrong unlike some other breeds :twisted: and this is a common swap
Posted: Tue Nov 02, 2004 8:55 pm
by tomsoffroad
Check out Mikes website 4wd.net.nz It has the wiring diagram for the engine. :D
Posted: Thu Nov 04, 2004 9:00 am
by SupraLux
Hi - I have the 5M-GE Supra Haynes manual I can send down to ya for a few days to get the relevant information if you'd like...
regards
Steve
Posted: Thu Nov 04, 2004 8:41 pm
by pinky
that would be good steve as the problem i am having is the engine is constantly running rich (and yes the cold start is off ) so a manual should get the problem sorted i hope this is very embarissing having to ask for help as i am a diesel machinc but have never worked on any petrol engines so dont quite understand air flow meters as i think this is where the problem may be so my address is 4 matai st pleasant point ( just 10 mins out of timaru ) ph 03-6148727 thanks . ps what do you drink ! :D
Posted: Fri Nov 05, 2004 5:57 pm
by SupraLux
You don't have a crook temp sensor (the little things with wires on em on the top front of the motor) do you? I seem to recall they could cause that or something similar - Mikes the man to ask about that.
The other thing I did :oops: was put my airflow meter in back-to-front - that made it run like shit :lol: Don't s'pose its something stupid like that?
Anyway I'll send it away in the next couple of days - Speights is my poison - next time you are in Chch buy us one each and we'll be square :)
Steve
Posted: Fri Nov 05, 2004 7:40 pm
by DJ
hi
dont forget to check cold start injector. This is known to leak but unfortunately its under the inlet manifold and a shit to remove.
Just my 2 cents worth :roll:
cheers DJ
keep us posted as I for one would like to see who the lucky winner is :wink:
Posted: Fri Nov 05, 2004 8:06 pm
by pinky
oh-gee-dah the AFM is fitted correctly and yes all the sensors are sending the correct signal (IE resistance) to the ECM . and DJ have checked the cold start injector and have also removed it from the enging and pluged all orifice's so pleace keep all the questions coming as am dying to go and have a play ...
Posted: Fri Nov 05, 2004 9:36 pm
by tomsoffroad
Whats the fuel pressure like Lloyd? What about the filter bolted to the side of the motor? I think yours has one, mine does :D
Posted: Sat Nov 06, 2004 2:28 pm
by DJ
hi (and Tom)
unlikely to be fuel filter as its running rich (thats too much fuel) and when fuel filters crap out they reduce out put pressure not create it.
anothor 2 cents worth :twisted:
DJ
Posted: Sat Nov 06, 2004 6:24 pm
by tomsoffroad
True :oops: :oops:
Posted: Mon Nov 08, 2004 6:30 pm
by DJ
hey Pinky
just wundering (?)what heat range of spark plugs are you using as I have just sorted out a simular problem on a customers car, same motor, same problem.
cheers DJ
Posted: Tue Nov 09, 2004 9:37 pm
by pinky
hmm spark plug been there done that also checked fuel rail pressure + engine compression and all is with in spec ( talked to suprsurf and have brought purchased a ECM to try . but this you make you all sick as i won lotto on saturday and hmmmm what to do .. as it was a very large amount . but hi ho hi ho its off to the big toy shop i go hehehe :) :) :) :) :) :) .
Posted: Tue Nov 09, 2004 9:44 pm
by pinky
please keep all the questions coming as i will be sticking with this project as it has been a lot of hard work and am so keen to get it running and bring it to CHCH and climb some rocks and brake some bits with all you guys ...
Posted: Tue Nov 09, 2004 9:48 pm
by tomsoffroad
Well done dude, whats on the shopping list then? :D
Posted: Tue Nov 09, 2004 10:05 pm
by pinky
hmmm looking at a marlin low box + auto locking diffs and a new engine as for the house thats up to the wife hint hint sorry about the spelling have bean on the piss 4 a fue days
Posted: Tue Nov 09, 2004 10:19 pm
by tomsoffroad
:lol:
Posted: Wed Nov 10, 2004 8:14 am
by De-Ranged
I know this is really obious but have you had a look at the air filter ??
or the inlet for the air box??
Congradulations, :D so whats the lotto fairy getting ya ???
Cheers Reece
Posted: Thu Nov 11, 2004 5:19 am
by tomsoffroad
Cough cough.... I know what you did wrong Lloyd!!!! cough cough!!!!! :oops: :oops: :oops: :oops: :oops: :oops:
Posted: Thu Nov 11, 2004 7:05 pm
by DJ
[b]a man who wins Lotto can do no wrong [/b]
now as a I have buttered you up. As I have paid into Lotto for years and won sweet F.A. I feel that I should have a small donation as, after all thats a chunk of my money you have. Hummer H2,s are on special and Xmass is just around the corner :P :P :P :P
seriuosly GOOD ON YA that man deserves a beer
oh well its worth a crack :lol: :lol: :lol:
Posted: Thu Nov 11, 2004 7:25 pm
by DJ
pinky
second thoughts :idea: I couldnt afford the up keep on the Hummer and I,ll trust you will spend my share wisely and I,ll have a beer for you just wave to us peseants from your Lear jet when passing by, we will wave back honest :P
I think I better have another ............... (Hic)..!! :twisted: :P :twisted: :lol: :twisted: :D :D :D :D :wink:
Posted: Thu Nov 11, 2004 8:33 pm
by pinky
wahoo wahoo life is f##ken good :D :D :D :D :D :D :D :D :D :D :D :D :D
Posted: Thu Nov 11, 2004 8:34 pm
by pinky
Posted: Thu Nov 11, 2004 9:07 pm
by tomsoffroad
So whens the shout? :D :D :D :D
Posted: Thu Nov 11, 2004 11:47 pm
by SupraLux
I\'m still sending the manual if you need it - I have had a busy coupla weeks and kinda forgot :oops:
regards
Steve
Posted: Fri Nov 12, 2004 8:49 pm
by pinky
hi all you peasants (joke) :) as for the win yippee but will as i am a young dude i will probably invest most of it as NZ is getting to be an old pouulation (sorry old dudes but it true ) and i will not be working as an old man as for the f##king surf it is still running like a pice of shit . fitted a new ECM tonight +new dizz + new spark plugs and leads + new coolant temp sender and gess what #### ALL difference (might just buy a 7M - GE himmmmmmmm but time will tell . cheers pinky :D
Posted: Tue Nov 23, 2004 7:24 pm
by pinky
well dont need any more help with the wireing anymore as the engine is now dead ( might have something to do with the hole in the block ) and the conrod sticking out of it > PS any one got some spear bits ie block conrod and pistion :(
Posted: Wed Nov 24, 2004 4:56 pm
by tomsoffroad
Tell a story :cry: :cry: ................. You must have got it running then?
Posted: Wed Nov 24, 2004 9:33 pm
by pinky
well pulled the engine down tonight and here is what happend No 6 conrod broke away from the piston and proceeded to snap the crankshaft and i dont know how but the conrod ended up half way through the cylinder head and what was left of the piston is now in the sump as shrapnal so yes it is all doom & gloom
Posted: Thu Nov 25, 2004 5:14 pm
by De-Ranged
:lol: :roll: Bugga!
If you want I can help you out with a block I've still got the spare one here... just got a small crack above the oil pump drive shaft, from when teh last owner dropped #1, easy fixed
:lol: as for the rest I just told teh engine recon shop to bin the spare crank pistons etc
don't buy another lotto ticket looks like you've used all your good luck up :wink:
If you'd like the block its yours just pay the frieght
Cheers Reece
