had a scarey oops
For all Nissan related topics
nuts
Location: somewhere arround westcoast offroading usually
had a scarey oops
Post by nuts »
had a front wheel fall off going to ch ch 2days ago wreaked the studs and slotted the holes that support the studs :evil:
mannaged to use a crow bar to streighten them enuf 2 get a wheel on :roll:
now the predikerment is can it b repaired or better to buy another hub and stub :?:
if replacement does anyone have the part that i can buy off them
mine is 1991 grandroad lwb
4x4skid
Post by 4x4skid »
hey mate,
its f?/#en scary ay, ive had it twice in my ute, once just rattled loose other time striped studs, and similar to you sloged out the holes they press into, i managed to reair mine by buying the next size studs, same thread but biger spline thru stud holes, drilled the holes to make them round intead of oval, smacked the new ones in and put a few spots of weld on the back of each stud, my 2nd time i wasnt so lucky and my tire hit an oncoming vehicle, evry1 ok but still, its not just trying to control a 3 wheel vehicle, its where that big lump of rubber is gonna go,
good luck
nuts
dam
Post by nuts »
4x4skid wrote:hey mate,
good luck
wadsnt that unlucky but me rims fucked and sloged pretty bad as sat on rim while towing a 1.5 ton trailer round a corner
