What size tyres for Hilux
Hi guys, I have a 1989, dbl cab hilux Which has had the origional 2.8 (3l) diesel (dead) replaced with a 3 litre (5L) engine
I am in need of replacing my tyres which are 31' kumhos and plan on going up in size to either 32x11.5xr15 or 33x12.5xr15
My question is would the 33's be to big for the engine and make the gearing too tall?
Cheers for your opinions
What are you using the truck for? Tyres aren't (well, they SHOULDN'T be) look-good accessories... if you're using the truck on the road or towing a lot, stick to 31's... if you're doing a lot of offroading go 33's
You might get some rubbing with 33's so also be prepared to do a little panel modification around the footwell area (a gentle beating with an 8lb sledge will fix it
Steve
Steve
SupraLux wrote:(a gentle beating with an 8lb sledge will fix it)
Steve
It's more like a massage........ with an 8lb sledge hammer
The 5l will have no problems pushing along 33" boots, although you will notice that the gearing is different. As Steve said, the 31" boots if towing or doing lots of hill work, 33"s for a capable 4wd truck.
DBWRacing wrote:good point but the wife also drives it occasionally so don't really want her driving a truck with bad road manners![]()
BFG muds and Wrangler MT/Rs are not bad-manners tyres... you'll find them both very easy-driving on the road... and 2 sets is a major PITA IMHO... I had two sets... they lasted about 2 changes before I got sick of doing that... now I just run Simexes everywhere
Steve
ive just got around to putting 33inch mtrs on my hilux ( thanks davem
). i still have the 2.8 and its not as bad as i thort it would be. yes theres a bit of rubbing when flexing. yes the gearing is all different and takes a while to get used to but the handling is just as good if not better. i guess its cos the track is wider.
but deffinatly go the 33's. youll love them and they make so much difference in the good stuff!
- muddyhilux
yeh im gona have to agree with steve on this one,ive been runing 2 sets of tyres for bout a year now and its geting dam anoying
,so like steve ive given up and am just gona stick with the one set,and ill trow in the muds i run are 33 bfg muds and like its been said by others i also find they drive fine on the road,wider trak makes my hilux sit beautifuly,but i can also vouch that they do sometimes let go in the wet
(2l petrol manual),i do have a heavy foot tho and do go for gaps,but yeh, just my 2c worth
