Wanted: GQ lower steering column bits thingeemabob
Posted: Fri May 04, 2007 9:36 pm
by turoa
Hi guys, I need a nissan lower steering column. I need from the box, up to another UJ or whatever is there. So basically I need the box spline, the rubber flexi bit, and up a bit.
Its needed for the LR project kinda soon. Cheers to anyone that can help me.
Re: Wanted: GQ lower steering column bits thingeemabob
Posted: Sat May 05, 2007 10:09 am
by GQTROL
turoa wrote:Hi guys, I need a nissan lower steering column. I need from the box, up to another UJ or whatever is there. So basically I need the box spline, the rubber flexi bit, and up a bit.
So you need the steering box, pitman arm off the bootom of it, plus the lower part of the steering column (incl flexy joint) that goes down to the box right? I've got one here, just I've got a bung arm at the moment, so may take a while to get it off.
Posted: Sat May 05, 2007 9:03 pm
by turoa
GQTROL wrote:turoa wrote:Hi guys, I need a nissan lower steering column. I need from the box, up to another UJ or whatever is there. So basically I need the box spline, the rubber flexi bit, and up a bit.
No, ive got a steering box, I just need the splined bit and flexi joint. and a bit of steering column so I can get it adapted to my holden column.
Posted: Sat May 05, 2007 9:10 pm
by GQTROL
turoa wrote:No, ive got a steering box, I just need the splined bit and flexi joint. and a bit of steering column so I can get it adapted to my holden column.
Will have a look tomorow to see how easy it would be to remove part of the lower steering column.
Posted: Sat May 05, 2007 9:25 pm
by turoa
GQTROL wrote:turoa wrote:No, ive got a steering box, I just need the splined bit and flexi joint. and a bit of steering column so I can get it adapted to my holden column.
