ln 65 hilux power steering
How hard is it to convert ln65 hilux to power steering truck currently has armstrong unit
Simple... the power steer box is a bolt-for-bolt replacement for the non-power steer unit... and you should be able to scavenge the hoses, reservoir and pump from a power steer unit and bolt them up - although you might need to shorten your steering shaft as the power steer box has a longer input shaft from memory...
It makes a huge difference...
Steve
Steve
- hosehustler
SupraLux wrote:Then forget the above and use a prado or an IFS surf power steer box and some high-steer arms and go crossover... you'll limit travel and just break things with the standard setup...
Steve
This is the way to go, definately forget the "normal" lux steering, here's a link of what you can do
http://www.offroadexpress.co.nz/modules ... pic&t=5192
I hate signatures
