Little green button
DaveL
Newbie
Newbie
Little green button
Post by DaveL »
Does anyone know what the little green button is for behind the gear shifter (auto) on my 94 Hilux Surf ? a light comes on with elec pwr in the dash ! It's been a year and I just gotta Know !
brianr70
Post by brianr70 »
I think it has something to do with the transmission :?
holds the 'gear' a little longer than usual [I think] :?
I travelled the road less travelled now where the heck am I!!!
dazza85
Post by dazza85 »
Brian is correct,
It it part of the electronic transmission control, it holds the lower gear longer giving quicker take offs and getting you to the higher speeds quicker.
The tradeoff is that it uses more fuel.
I leave mine in eco most of the time on the road,
Some times use it off road ... Not sure what difference it makes in this situation.
Would love to know what others do.
wjw
Post by wjw »
Changes the shift point by 500 RPM
Who knew Prados could fly?
mike
Last minute Mike
Post by mike »
It makes a huge difference when towing through hills, stops the auto jumping around all the time at the wrong time.
Mike
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
rangimotors
Post by rangimotors »
I don't bother using mine on-road unless im climbing hills and want a little more power just hangs in gears for a little longer assuming your using drive and not selecting through the gears, use mine off-road a bit, i like the rev's to spin the wheels and clear the tyres, also leave overdrive turned off off-road cheers..
wopass
Post by wopass »
wjw wrote:Changes the shift point by 500 RPM
what he said
