has anyone got one of these lyin around that needs a new home??
or has anyone made one and have list of what i need and pictures etc??
cheers....
413 snorkel
413 snorkel
- mroffroader
- mroffroader
I got a straight bit of around 2.5" at the exhaust shop, they swaged it down to fit the bit of flexi hose I got to connect to the airbox. I welded on a couple of bits of angle to mount it off the old aerial screw holes & cut a hole for it straight down into behind the dash, & then fed the flexi hose to it through another hole cut in the firewall & ran a bead of sealant around the holes.
For the scoop I just bent one up in the vice out of 2mm alu & riveted it on.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
