I have a 89' LJ71 & am doing the diff's soon , they are Open & give me the shits offroad as get bogged easy , I will be dropping in a Powetrax "No-slip" in the rear , am looking at gettn a LSD for the front .i think my ratio is 4.3 ( having a look this weekend to make sure )
I have seen heaps of 4.8 ( 4.88 ? ) hilux LSD's around cheap on trademe, etc , have heard from another source somewhere that this LSD carrier can only have that particular ratio C & P & won't work with any other ratio .
Wondering if this is true or false ?
I hear the Hilux 4.8 LSD carrier can't use other ratio C&
adventures_more
yep thats the case, better to buy the whole head with the ratio you want.
Altho i would have thought you could drop the 4.88 LSD centre into a 4.3 head, therby basically converting your open 4.3 into a LSD 4.3 using a 4.88 LSD centre......could be wrong tho
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
