Hi
Can one of you guys messing with a lexus v8 tell me how wide it is and long also , ie from g/box mount to front of pulley .
Chris
Size of lexus v8
your looking at
75cm long to edge of the viscus fan (5cm for the fan), 73 wide ( if you need to you could lose about 5cm of this by moving the power steering pump) your widest part is the tappit covers so throw a fair bit in for engine movement
The length dosn\'t include a bellhousing, its just up to the edge of the block
These are off a 1UZ soarer V8
Hope this helps
Cheers Reece
Hope this helps
Cheers Reece
Cheers Reece
De Ranged Engineering
027 541 8794
027 541 8794
