transfer case crack
transfer case crack
The housing that the 4wd vacuum diaphragm mounts to has a crack that is leaking at 30 second intervals cold.
What would i need to weld it ?
microwaved cheese on toast
- safari_mulisha
- safari_mulisha
adventures_more
weld
grind the crack a bit , both sides, might concider drilling a small hole at the end of the crack to stop it cracking in the same spot
