Rubber boot for Nissan Transfer Case
brakes-shocks-lockers-etc
Mikey
Post by Mikey »
Just wondering if anybody knows the best place to get a new transfer case boot as the one on my truck now is torn and is letting water and mud into the cab. Its for a Nissan Mistral, so i guess a Terrano one would do the trick.
If anyone has one they don't need; or know a good place to source one from, let me know. Any help is much appreciated.
Mike
kiwipete
Re: Rubber boot for Nissan Transfer Case
Post by kiwipete »
Mikey wrote:Just wondering if anybody knows the best place to get a new transfer case boot as the one on my truck now is torn and is letting water and mud into the cab. Its for a Nissan Mistral, so i guess a Terrano one would do the trick.
Mike
If you mean the one on the HI/LO stick, Terranos have a bad habit of splitting.
I made one from some Vynal from an upolstorer (sp), marine grade. Cut it to make a cone shape from thick plastic first and when the shape was acceptable, cut this from the vynal. glued the seam with Ados glue and when dry ran the sewing machine over it a couple of times.
Used silicone sealent around the base, top and bottom etc. Cutthe bottom seam of the old boot to assist with pressure when screwing back into place.
siliconed the top section and used a cable tie to secure.
Have had no probs since.
I believe the origonals are too hard a rubber and as such are prone to the splitting sindrome.
All the ones I found ar wreckers were the same.
Ph 0212078472
Ryan
Post by Ryan »
pm daisy because he got some kind of boot from a plumbing shop...
Mikey
Post by Mikey »
Yeah, it is the rubber boot on the transfer lever. Looking at it, I too think the rubber was initially to hard, or has hardened up over time.
Cheers for the help guys
Mike
Terry
Post by Terry »
When mine went (on the patrol) the Ni$$an price scared me shirtless - got the smallest CV boot they had at Repco (from a daihatsu something), chopped the top and bottom off till it almost fit, and siliconed it on. Works a treat. Might be a bit bigger than a Mistral one, but it doesn't hurt to see what you can find...
doddzee
Is Doddgee
Post by doddzee »
Bike inner tube, Cable ties and a bit of black tape does the trick :wink:
MWB V8 Safari Ute
turoa
Pyro Junior
Post by turoa »
doddzee wrote:Bike inner tube, Cable ties and a bit of black tape does the trick :wink:
If you're a hillbilly it will
doddzee
Is Doddgee
Post by doddzee »
Well Mikey is a southerner their all hillbillys down there arent they? :scratch: :D
MWB V8 Safari Ute
kiwipete
Post by kiwipete »
If the mistral is anything like the Terrano, you will need more than a bike inner tube as the base area is approx 200mmx125mm in size.
Ph 0212078472
Mikey
Post by Mikey »
I will let that that comment slide - it wouldn't be the first time cable times have fixed something of mine :oops:
Cheers for the suggestions guys
Mike
albundy
Rolly Polly
Post by albundy »
Automotive Parts in Rangioria. Dedicated Nissan wreckers, especially all Nissan 4wd's. I'm sure they coud get somethng to you. Tell them Al sent you.
Al
daisy
Post by daisy »
:wink:
