oil coming out breather?
Posted: Mon Jun 04, 2007 6:51 pm
by fish
im looking at buying a 89 bighorn. it all looks good but there is one thing that concerns me. there seams to be a bit of oil coming out the breather.
the owner says that it only hapens on long journys and not round town. has any one heard of this problem before and anyone know the solution.
any ideas would be great.
cheers. :D
Posted: Mon Jun 04, 2007 11:06 pm
by daisy
:wink:
Posted: Tue Jun 05, 2007 6:40 am
by albundy
Or there is water in the box/diff wherevee the breather is coming from. Pull out the fill plug, stick your finger in and see what the oil is like.
Al
Posted: Tue Jun 05, 2007 8:45 am
by Aaron
That is a common fault on the isuzu deisels, run a hose from the breather into a catch can, then another hose back to the intake. On the bottom of the catch can run a small hose down and join it into the side of the dipstick tube so the oil runs back into the sump.
Andy at Amma motors in Christchurch makes these up out of alloy to suit he sell a kit which bolts on and solves the problem Ph 3660 454. :wink:
Posted: Tue Jun 05, 2007 10:45 am
by fish
thanks. is there any way this could develope into something more serious?
Posted: Wed Jun 06, 2007 6:51 am
by Mattman
If there is any blowby at all on a forced induction motor then the crankcase gets pressurised.
A lot of NA cars that get blown suffer from this, the amount of blowby can be minimal but still cause oil to come out.
The catchcan mod will work well. If you are looking at buying the vehicle then you should get it checked out by someone before buying to make sure there aren't any problems.
Matt.
Posted: Wed Jun 06, 2007 3:01 pm
by safari_mulisha
a catch can with a breather on it wont work
it will fill your engine with water when you go underwater
use a catch can with the breather that goes back before the turbo
then its totally sealed but can breath
one step better is what i run on my rb30det a recirculating catch can with a sump breather
you can see it behind the drivers head light
Posted: Wed Jun 06, 2007 10:34 pm
by fish
blow by? what is this?
Posted: Wed Jun 06, 2007 11:22 pm
by safari_mulisha
During normal operation, a small amount of unburned fuel and exhaust gases escape around the piston rings and enter the crankcase, referred to as "blow-by". [6] If these gases remained in the crankcase and condensed, the oil would become more diluted over time, decreasing its ability to lubricate. Condensed water would also cause parts of the engine to rust. [7] To counter this, a crankcase ventilation system exists to draw fresh air in from the air filter and expel the gases out the PCV valve into the intake manifold. The intake manifold is at a lower pressure than the crankcase, providing the suction to keep the ventilation system going.
If an engine is damaged or enters old age, gaps can form between the cylinder walls and pistons, resulting in larger amounts of blow-by than the crankcase ventilation system can handle. The gaps cause power loss, and ultimately mean that the engine needs to be rebuilt or replaced. [6] Symptoms of excessive blow-by include oil being pushed up into the air filter, out the dipstick[8], or out the PCV valve.
souce was wikipedia
Re: oil coming out breather?
Posted: Thu Jun 07, 2007 4:39 pm
by Tonkar
fish wrote:im looking at buying a 89 bighorn. it all looks good but there is one thing that concerns me. there seams to be a bit of oil coming out the breather.
cheers. :D
I had a Mu with a 2.8turbo and she did the same thing it will only get worse trust me i wouldn't touch it unless you want to do the engine. Mine used to fill a 2ltr coke bottle in 3 days on a long trip and it only got worse! ended up replacing the engine
