Engine dies at idle and splutters under load
Posted: Mon Jun 04, 2007 7:43 pm
by jumper
Engine dies at idle and splutters under load it will run on the choke but does not sound right
I have checked for vacuum leaks, checked the timing, fuel and fuel filter, fuel lines, coil, leads, spark plugs and dizzy they all seem to be ok.
Cleaned the rochester 2bl carb out the jets are clear, how do you check the mech fuel pump?
Posted: Tue Jun 05, 2007 8:03 am
by tristanp
still sounds like a vacuum leak , could be a blocked idle jet though
Posted: Wed Jun 06, 2007 6:55 am
by Mattman
Does sound like a air leak of some sort if using the choke fixes it.
You mentioned it was leaking fuel the other day, I would be checking the float level in the carb to make sure it's not too high or too low.
Hard to check the pump - the output pressure should be somewhere around 4 psi and you can do a volume check by running the pump into a large bucket and timing the flow.
Matt.
Posted: Wed Jun 06, 2007 1:51 pm
by Ryan
very similar problem with my zuk... mechanic checked for vacum leaks etc
they all good and he rekons theres shit in the carb.......??
Posted: Wed Jun 06, 2007 5:08 pm
by Heath
for the zuk carb an old trick is to remove all the stuff off the carb top (so you can get clear access to the barrel)get it running and rev it up and then block the throat so it stalls (or nearly stalls). This clears any crap out of the jets and can be a usefull trick if stuck on the road side. Some say use the flat of your hand but I dont like that idea (especially on a bigger engine) so a flat clean piece of wood / steel maybe is safer(something that wont break up and send rust or splinters into the engine is best).
This is just a trail fix and may give some respite for the trip home but is in no way the proper way to fix the problem. A full tear down and clean is the proper way, but you never know...
Heath
Posted: Wed Jun 06, 2007 5:29 pm
by Sadam_Husain
I've got a spare rochester quadrajet in the shed you could try but its a 4BBL not a 2BBL
did you just blow compressed air through the carb jets and passages? I've just had my holley overhauled and the guy put it through his acid bath to eat all the shit out of it.
Posted: Thu Jun 07, 2007 3:12 pm
by jumper
Pulled the carb right off and found that a bolt that holds the venturi cluster to the carb just spins in the hole
i was going to put a new kit on the carb but there is no point if the carb will never work properly, i might as well put the $60 towards a new/used carb .
Would the quadrajet bolt right on to a 350 ?
Posted: Thu Jun 07, 2007 4:10 pm
by Sadam_Husain
If your carb is a 2BBL you'd have to find another one or swap your inlet manifold over to a 4BBL.
Once you've gone 4BBL you can use adaptors to swap between spread bore (Rochester) and square bore (Holley) carbs. Old cast iron 4BBL manifolds are just about give away's now :thumright:
Posted: Thu Jun 07, 2007 5:41 pm
by jumper
yep manifold is 2bbl so that means new/used carb and manifold.
Anyone got either
Posted: Thu Jun 07, 2007 5:46 pm
by Mattman
