EFS 100mm(4")front springs (215lbs)
well fit LWB/SWB GQ nissan Safari's.
These are a soft spring to help front articulation.
I brought these new on 3/6/06
Load Bearing accessories up to 45 kg. Free Height LHS:470mm RHS:480mm. Inside diameter:124mm. Total Coils:9. Linear. Wire diameter:17mm. Spring rate:215 lbs. Use extended sway bar links with these springs. Use long travel shock absorber with these springs.
Shane
$175
F/Sale EFS 4" Front Springs(Safari)
You need longer shocks(I used std ones for few months but vehicle wont have any drop)I use 80# landcruser, monroe 4x4 shocks from repco(quite cheap and good shock for club truck)
You need some sort of caster adjustment,bushes,drop box's etc and panhard adjustment which I never got round to.I can sell you my drop box's if that helps as I well need to make new ones for my new springs.
Shane
021338855
Shane
021338855
