ISuzu trooper question
xeus
Post by xeus »
i have got this isuzu trooper 84 model ...i need to know that can i get into 4wd and start climbing steep mountains with it? like these mountains have road pavement roads? can i shift into 4wd and use 4wd? coz i have heard that 4wd should not be used on hard roads??? can any one help me out??plzzz...
Kent
No
Post by Kent »
No you can't. It is not good practice to use your 4wd on tarseal, You can get a thing called windup, which will screw your running gear. The reason is when you go round a corner the inside wheel travels a shorter distance then the outside wheel. So something has to go and sometimes the wheel will skip or something will break.
Kent
