What paint do I use?
Beer_Cruiser
Post by Beer_Cruiser »
I've just had bull bars sandblasted and now I want to paint them.
What sort of paint, undercoat do I use?
I dont have a spray unit so I will probably have to brush coat.
Or am I better off sending it to someone to spray or powdercoat just to be done with it? What sort of price should I expect?
Any help would be appreciated. (no emoticons)
Jafa
Post by Jafa »
POR 15 is not bad shite, not cheep tho
021 273 9942
jafa@inspire.net.nz
mroffroader
Post by mroffroader »
Id just paint it with spray cans, I would primer it first then paint matt black (or flat black) as its cheap to respray/touch up when it gets knocked about and scratched and matt black makes even the ugliest things look good :wink:
Beer_Cruiser
spray cans sounds good and cheap. what sort of primer should I get? and whereabouts would i find it?
niblik
Post by niblik »
use durepox fella...
goes on sweet as with a paint brush and dries as a matt finish.. best part is its real solid and if you do happen to chip it by hittin a small continent, touch ups are easy as..
relatively cheap too..
:wink: :D
mroffroader
Beer_Cruiser wrote:spray cans sounds good and cheap. what sort of primer should I get? and whereabouts would i find it?
Where abouts are you in welly? i can give u a hand this weekend if you like
Beer_Cruiser
durepox...mind sound like a stupid question but whereabouts do i source that from?
niblik
Post by niblik »
resene auto shops supply.. any auto paint like store should supply...
icekayak
Post by icekayak »
Personally i would use hammerite paint...
No need to prime or anything and has that hammered look with metallic particles so it covers up alll the imperfections well... and makes a reasonable finish too...
Takes a while to harden properly but is faily strong after that...
they recon you can paint straight onto rust, but i'd normally give it a light sand... and then just slop it on nice and thick with a brush..
Avaliable in tins or in spray cans (never tried them though)...
Mitre-10, Bunnings, local paint store (car colours) all have it up here in auckland...
http://www.hammerite.com/uk/products/ps_dtr_metal_paint.html
MudBum
Post by MudBum »
My vote: Durepox..When dry, 100% water impervious..and only Resene Automotive Stores have it,any colour about $140ish for a 5lt kit.One draw back is its a 2pack (has hardner)only nasty when sprayed but brushed is sweet(use gloves,and its a bit smelly)
Buy far the best stuff around for what we do,IMHO :wink:
P.S. No i do not work for Resene :wink: Im a Windscreen Guy 8)
icekayak
Post by icekayak »
do you know how much for 500ml or 1L?
mroffroader
Ended up just painting with matt black paint for beer-cruiser turned out all right and when in gets knocked and bumped its easy and cheap 2 touch up :wink:
MudBum
Post by MudBum »
icekayak wrote:do you know how much for 500ml or 1L?
From memory about $40odd
Beer_Cruiser
Bull bars look good thanks for all the help will try and get some photos
Return to “Tool Shed”
